The day a computer took charge of a Texas refinery
Posted: October 16, 2026
Around 1956, when Texaco’s chief process engineer Charles Richker first started playing with the idea of letting a computer run part of a refinery, it seemed like science fiction. He later admitted that the notion had sounded like “Buck Rogers stuff,” and that the hardware wasn’t ready anyway. Three years later, it was. On March 12, 1959, at Texaco’s refinery in Port Arthur, Texas, operator Marvin Voight threw a single switch.
“Moments later,” Business Week reported a few weeks afterward, “the most vital parts of the 1,800-bbl.-per-day polymerization unit […] were under the unblinking eye and almost instantaneous control of a Thompson Ramo Wooldridge Corp. RW-300, a desk-sized digital computer designed for just such control jobs as this.” The magazine described it as an industry first: no computer had fully automated an industrial process before.
Texaco hoped the computer would raise the unit’s efficiency by 6–10%. Follow-up reports later found it was converting 91–92% of its propylene, up from a historical 82–83%, and saving $75,000 a year on catalyst. But the stakes went well beyond one small refinery unit. Business Week reported that computer makers were eyeing a market worth $100 million to $200 million a year. Chemical and oil producers imagined productivity gains of up to 15%.
Nearly seven decades later, the loop Voight closed has become the backbone of modern industry. Here’s how a Texas refinery experiment grew into the control systems that run today’s plants.
Our Industrial Life—delivered
Why Texaco handed a refinery unit to a computer
In 1959, Texaco’s Port Arthur complex had a throughput of 280,000 barrels of crude oil a day, making it the fourth largest refinery in the U.S. The polymerization unit, which had been running since 1942, had a deceptively simple job. It took propylene, a gaseous byproduct of the refinery’s catalytic crackers, and chained its molecules together into a high-octane gasoline component.
The economics were irrefutable: liquid propylene was worth about $1.10/barrel, while the gasoline component fetched $5.
But the process itself was finicky: the temperature had to stay between 470°F and 490°F. Too cool, and the reaction stalled. Too hot, and the catalyst degraded. Whenever the upstream crackers changed their feed, “bumps” rippled through the gas stream, causing temperatures to fluctuate beyond the limited acceptable range. Manually bringing the unit back to a steady state could take half a day, and someone watching roughly 50 instrument readouts had no realistic chance of working through the catalyst chemistry and adjusting the settings before conditions shifted again to keep the plant running at maximum efficiency.
The RW-300 changed all that. It drew on 110 data sources and adjusted 16 flows, pressures, and temperatures. The entire cycle could run every five minutes, 24 hours a day. Up until this point, the few computers installed in plants had only monitored conditions or advised the people running them. Now one was setting the controls itself. Most of its adjustments went to the unit’s existing pneumatic controllers, resetting their targets. But it drove the reactor feed valves directly, with no controller in between. In hindsight, that made it the first example of direct digital control too, though the team didn’t realize it at the time.
Right: The RW-300 computer (foreground) in operation while Texaco and Thompson Ramo Wooldridge employees check control charts. Left: One of the control charts. The bump in the chart shows effects of a feed change. Source: Business Week, April 1959.
The RW-300’s operation at Port Arthur was later recognized as the first achievement of true closed-loop computer control of an industrial process. But that didn’t mean the operators were made obsolete. The computer checked its readings for anything abnormal, and as Business Week reported, “If something goes haywire, the computer detects the fact and yelps for help…”
Getting to this level of automation took more than two and a half years and a 318-page feasibility study. The computer alone cost $98,000—over $1 million in today’s dollars. Further steps to fully autonomous operations would come later.
From adjusting the controls to replacing them
Each new generation of control technology pushed automation further. The RW-300 had mostly supervised conventional controllers. The next leap came in 1962 when Monsanto’s ethylene plant in Louisiana and ICI’s soda ash and ammonia plant in Britain deliberately handed computers direct control.
When the Ferranti Argus computer went live at ICI’s Fleetwood plant in 1962, it became the first large factory controlled directly by a digital computer. Later Argus models were used to run the British National Grid, to control North Sea oil production pipelines, to control biscuit production lines and to make every inch of Kodak’s 35mm film. They were used in research at CERN and to control Boeing wind tunnels and were still running in some British nuclear power stations as recently as 2025.
On factory floors, a different revolution was brewing. In the late 1960s, General Motors’ Hydramatic transmission division estimated that downtime on one production line cost $1,600 a minute. At the time, new cars sold for around $5,000. Much of the downtime came from huge banks of unreliable electromechanical relays. They took up a lot of space and required lots of time to reconfigure. The engineers were eager to be rid of them.
The programmable logic controller, first delivered to General Motors in 1970, replaced walls of failure-prone relays. But its real breakthrough was designing around the people who would use it. Its ladder logic let electricians program it using the same diagrams they already drew for relay circuits.
The rise of distributed control systems
The RW-300 had put a single computer at the heart of a plant. By the mid-1970s, microprocessors made it possible to spread control out. In 1975, Honeywell launched its TDC 2000 and Yokogawa announced its CENTUM. Both companies still describe theirs as the world’s first distributed control system.
With control split across many smaller controllers, a single failure no longer threatened the entire plant. Operators traded walls of analog dials for screens, and the control room began to look more automated than ever. But someone still had to be sitting in it.
Can AI take the next step?
Today the challenge has shifted again. IoT Analytics puts the cost of unplanned downtime at an estimated $1 trillion a year. Veteran workers who know how to fix things are retiring. At Hannover Messe 2026, an AWS solutions architect said 65% of manufacturing maintenance teams are expected to lose critical knowledge.
Researchers are now testing whether AI can take on some of that judgment. In a June 2026 preprint, a team from Imperial College London and Helmut Schmidt University in Hamburg described a system of large language model agents that respond when a plant fault is detected. The agents plan a corrective action and test it in a digital twin before anything touches the plant. If no safe plan emerges in time, control passes to the plant’s safety system.
In simulated tests on a mixing plant, the stronger of the two models handled all 60 fault runs without a single failure. But the authors caution that decisions taking several seconds rule the approach out for processes that need hard real-time responses.
If that sounds ambitious, so did Port Arthur. Back in 1959, the refinery’s works manager, Henry Flynn, was already looking past the little polymerization unit to the refinery’s far more complex catalytic crackers. He offered a prediction that could have been written about AI today. “Six years ago it was over the hill—absolutely out of sight,” he said. “Now, it’s just a matter of a few more years of hard work.”
Today, the Port Arthur refinery is the country’s largest. And an RW-300 console donated by Texaco sits in the Smithsonian’s collection.
Resources:
Programmable Logic Controllers: The Evolution of a Disruptive Technology (Engineering.com)
The Dawn of the Programmable Logic Controller (PLC) (Automation.com)
Computers in Control (Computer History Museum)
The computer that ran a nuclear power station | TNMOC Talks (YouTube)
