Posted: October 07, 2026
Calcamite designs, manufactures, operates and maintains small-scale, modular wastewater treatment plants for remote communities and commercial sites across Africa.
Read on for:
Small-scale, on-site treatment lowers cost, supports water reuse, and reduces energy
- How decentralized wastewater treatment can reduce dependence on overloaded municipal systems while allowing infrastructure to grow alongside demand, saving money and the environment
The challenge of maintaining scattered remote plants
- How Calcamite shifted from reactive maintenance to real-time visibility
A connected plant proves the model
- How connecting plants at Gourikwa Nature Reserve led to real-world gains
Data makes decentralized infrastructure scalable
- How Calcamite plans to use similar data architecture to scale the connected model to as many as 1,000 plants
Building infrastructure for a different future
- How decentralized wastewater treatment is a scalable solution for a sustainable water future
For communities across Africa, access to safe water and wastewater treatment is an infrastructure challenge with far-reaching consequences for human and environmental health. Aging and overloaded municipal systems struggle to keep pace with growing demand, while droughts, floods and limited funding put additional pressure on already constrained resources. In South Africa alone, hundreds of municipal wastewater treatment plants are in a state of disrepair, contributing to pollution risks and mounting maintenance backlogs. A recent audit found that nearly half of wastewater facilities in South Africa are in a critical state.[1]
Calcamite is tackling the problem head-on. Rather than waiting for centralized infrastructure to catch up, it is bringing wastewater treatment closer to where it’s needed. Based in South Africa, Calcamite designs, manufactures, operates and maintains small-scale, modular wastewater treatment plants for remote communities and commercial sites across Africa. Already, Calcamite has installed more than 2,000 of its plants in the field. Collectively, they treat approximately 2.3 million cubic meters of wastewater every year.
But decentralizing wastewater treatment creates a challenge of its own: how do you effectively operate and maintain thousands of small, remote plants when you can't have people on site all the time?
For Calcamite, the answer involves a data solution that’s as smart and purpose-built as its plants.
Read AVEVA’s reporting: Why tackling water scarcity requires a rethink on technology investment
Traditional wastewater infrastructure depends on large, centralized treatment facilities and extensive sewer networks. For many developing communities, expanding that infrastructure can be prohibitively expensive, slow and difficult to maintain.[2]
Decentralized treatment can reduce dependence on overloaded municipal systems while allowing infrastructure to grow alongside demand. A remote community, eco-tourism destination, or mining site can deploy treatment capacity where it is needed and expand incrementally over time, avoiding the cost and complexity of extending centralized wastewater networks.
The benefits extend beyond capacity. Treating wastewater locally can reduce the need for extensive infrastructure, lower capital and operating costs, support water reuse, and reduce the energy associated with transporting wastewater over long distances.
It can also help protect the environment. Instead of allowing untreated or poorly treated sewage to enter rivers and groundwater, decentralized treatment provides a way to manage wastewater at its source while recovering water and nutrients.
But there is an important caveat: decentralized infrastructure is only as effective as its operation and maintenance.
Our issue was that we couldn’t see what was happening at the plants. I wanted something accessible. The monitoring system cannot cost more than the plant.
Calcamite’s modular plants treat wastewater at or close to its source. Wastewater from the existing septic tank enters the plant, passes through a series of treatment processes, and is disinfected to produce water suitable for non-potable applications such as irrigation and mining.
These smaller local plants perform well when operated within their design capacity, maintained routinely and kept running reliably. Historically, however, Calcamite found that maintaining remote plants was challenging.
Without real-time visibility, Calcamite often had to rely on reactive maintenance. If a pump failed or a plant began operating outside its normal parameters, the first indication might be a customer complaint—or a smell. By then, the problem had already become an operational and potentially environmental issue.
Sending technicians to remote sites every time something went wrong was neither efficient nor economically sustainable. At the same time, traditional automation solutions could be too expensive for small-scale plants, particularly where funding for infrastructure is already limited.
Calcamite needed a way to bring the benefits of digital operations to its dispersed infrastructure without undermining the lean economics that made the model attractive in the first place.
Calcamite began testing its approach at Gourikwa Nature Reserve. The nature preserve was initially interested in integrating Calcamite’s modular system with its existing septic tank but was concerned about maintenance costs. So Calcamite covered maintenance for the first year, de-risking the project for the customer while giving the company an opportunity to prove that remote monitoring could reduce the need for costly site visits.
For the pilot, Calcamite partnered with AVEVA and AVEVA Endorsed Partner 4Sight to develop a monitoring and automation solution that reflected the plants themselves: modular, scalable, cost-effective and robust enough for remote environments.
Schneider Electric edge technology connects the plants to CONNECT, giving Calcamite remote visibility into performance across different hardware environments. Teams can monitor operating data, identify emerging problems, and deploy software updates without traveling to each site.
And with CONNECT Industrial AI Assistant, teams can ask questions about plant performance and receive contextual explanations without manually working through disconnected operational data.
The result is a fundamental shift in the maintenance model—from responding to problems after they happen to identifying and addressing issues proactively.
[Teams] can go into the CONNECT’s AI Assistant, ask questions, and get a good explanation of what went wrong and how to solve it.
The reserve’s wastewater treatment plant now treats approximately 15 cubic meters of wastewater per day.
Calcamite reduced monthly maintenance costs at the Gourikwa Nature Reserve site by 85% in the first five months of operation, while recovering more than 2,123 cubic meters of water for groundwater recharge.
The plant also recovered approximately 63 kilograms of nitrogen and 6.3 kilograms of phosphates, helping turn wastewater treatment into a resource-recovery opportunity rather than simply a disposal process.
By treating wastewater locally, the project avoided an estimated 22,656 km of sewage transport and approximately 30 tons of CO₂ emissions. It also prevented an estimated 400 square meters of land loss and 6,000 cubic meters of soil pollution.
For Calcamite, however, the significance goes beyond the results from a single plant. The ambition is to scale the connected model to as many as 1,000 plants.
This is where the data really goes to work in creating the foundation for a new operating model—one in which a relatively small team can gain visibility across a distributed network of wastewater assets, prioritize interventions, reduce unnecessary travel and standardize how plants are operated and maintained.
Every morning I log into the AVEVA CONNECT site, and I can see all my plants.
Africa's infrastructure challenge cannot be solved by simply replicating centralized models. Funding constraints, dispersed communities, water scarcity and aging infrastructure require approaches that are more flexible and economically sustainable.
Calcamite’s experience shows that decentralized treatment can help fill this gap when plants can be monitored and maintained reliably as a connected network. For communities, that creates the potential for more dependable wastewater services, greater water reuse, and lower environmental impact. For Calcamite, it provides a path to scale its vision of a sustainable water future, one connected plant at a time.
AVEVA has a suite of software for the water industry.
[1] Vecchiatto, Paul. (2 April 2026). “Half of South Africa Wastewater Plants Deemed in Critical State.” Bloomberg. https://www.bloomberg.com/news/articles/2026-04-01/half-of-south-africa-wastewater-plants-deemed-in-critical-state
[2] EPA. (26 June 2026). “About Small Wastewater Systems.” https://www.epa.gov/small-and-rural-wastewater-systems/about-small-wastewater-systems
Related blog posts
