AVEVA Insight | July 2020 update. Part 2
Posted: July, 22 2020
Insight | July 2020 - Part 2
Discover the latest updates to AVEVA Insight
Hi! Today we have another installment of the AVEVA Insight blog where we explore what's new in Insight - your cloud platform for operational continuity.
This month we have already showcased a number of new features including new branding, improved asset management and the new alarm page. Now, we are going to explore some exciting new capabilities for improving production performance.
What's new - July 2020, Part 2
- Production Line Modeling
- Production Line Monitoring
Introducing a new Production Line Modeling page where you can define your production line, manufacturing line or assembly line using a simple drag-and-drop interface. Access to this new page is through the Efficiency tile in the Administration portal. From here you can search for, and add equipment, and draw connections between elements to quickly create an accurate model.
Plus, the new Production Line Modeling page also allows you to indicate bottleneck equipment, and production source equipment. You can identify target OEE values, and include Namespace, Name and Location. Layering in all this context builds a richer model that becomes a digital twin of your physical production line.
The final step in the modeling sequence is validation and publishing. By validating your production line, you can be assured that once you publish your model that it is working as an accurate digital twin, with no circular paths and a bottleneck and source equipment in each path through the line.
Production lines can also be duplicated so that you can replicate the same configuration across multiple lines quickly and easily.
Published models then appear on the Equipment Efficiency page, and give an immediate overview of how each production line is performing. At-a-glance you can see state, status and KPIs for the production run including OEE and production rate. With a snapshot view across the entire line, you can also quickly drill-down to the individual equipment components by clicking on the relevant item.
Production Line Monitoring also allows you to add Events to bottleneck equipment using equipment utilization reasons such as slow running, or planned and unplanned downtime. Authorized users can stop or start a production line using the Production Run start/stop button at the top of the page. When starting or stopping a production run, you will have the option to enter OEE context data such as crew details, batch ID, and work orders. even desired production rates by equipment. When starting a production run, you can select which bottleneck or production source equipment to start and set the desired production rates by equipment.
Since all the reasons codes come from your pre-populated time-usage model, it is much easier to identify improvement opportunities and increase your production performance. And since the model allows OEE to be tracked at a line level, in addition to individual pieces of equipment, you now have a more comprehensive understanding of overall production performance.
Well, that's it for Part 2 of the July 2020 update. Stay tuned for more exciting updates next week and in the meantime please let me know what you think of the new Production Line Modeling and Monitoring capabilities by commenting below.
Keen to learn more?
If you would like more information about anything in today's blog please contact your local distributor, or speak to our team at [email protected].
And remember, if you don't have an AVEVA Insight account, you can get started today with our 45-day FREE trial, simply sign up at https://insight.connect.aveva.com
