Posted: December 16, 2025
When process simulation and detailed engineering live in separate silos, projects slow down, handovers break, and design assumptions get lost. AVEVA tackles this head-on by tightly integrating AVEVA™ Process Simulation and AVEVA™ Unified Engineering, offering a quick file-exchange, but also a data-centric, bi-directional workflow, connecting process models with PFDs/P&IDs, datasheets, 3D models and the engineering database. The result: fewer rework loops, faster FEED-to-detailed-design handover, and simulations you can trust and reuse across the entire asset lifecycle.
Why AVEVA created this integration
Behind this integration, there are three practical drivers:
- Close the loop between process thinking and plant reality. Process engineers create models to size equipment, predict behavior and define operability. Engineering teams then turn those outputs into P&IDs, datasheets and 3D layouts. AVEVA’s integration removes the friction at this handover, so that simulation outputs feed directly into engineering artifacts and engineering changes can flow back into the simulation. This is the essence of a data-centric engineering approach.
- Foster multidisciplinary, cloud-enabled collaboration. AVEVA Unified Engineering is a single, cloud-enabled hub for 1D, 2D, and 3D engineering disciplines on CONNECT. Integrating simulation into that hub lets distributed teams work from a single source of truth rather than reconciled spreadsheets and disparate files.
- Support lifecycle reuse and digital twins. Use the results from your simulation from FEED through detailed design, commissioning, and operations (including integration with systems such as AVEVA™ PI System™ for digital twins). Embedding AVEVA Process Simulation into AVEVA Unified Engineering makes those lifecycle handoffs practical and repeatable.
Customer benefits
Customers will immediately see multiple high impact wins from the integration:
- Single source of truth and fewer errors. With process simulation, datasheets, and P&IDs linked, discrepancies caused by manual copy-paste are dramatically reduced, which lowers the risk of costly change orders during construction.
- Faster FEED-to-detail handover. Simulation results (e.g., equipment sizing, operating points) can be published into engineering deliverables faster, accelerating design maturity and shortening project schedules.
- Traceability and change propagation. If process conditions change, updates can propagate through engineering documents and models, ensuring consistent design decisions and simpler impact analysis.
- Reuse across lifecycle: design to operations. The same validated simulation can be used for safety studies, optimization and digital twin scenarios, giving long-term value beyond the capital project.
- Cloud-enabled collaboration and global workshare. Teams across geographies can work concurrently on the same engineering dataset in AVEVA Unified Engineering, avoiding time-zone handover delays and conflicting revisions.
Why this makes AVEVA Process Simulation stand out versus other simulators
Many process simulators are powerful on their own, but the market differentiators today are ecosystem integration and lifecycle value. Here’s how AVEVA’s approach stacks up:
- Native, bi-directional integration into a data-centric engineering hub. Rather than an add-on connector, AVEVA embeds process simulation into AVEVA Unified Engineering so that data flows are built into project workflows and the engineering database. This tight coupling reduces manual reconciliation and supports global workshare. Most other products on the market, on the other hand, require manual exports/imports or custom integrations.
- End-to-end reuse from FEED to operations. You can reuse AVEVA Process Simulation across the entire asset lifecycle (steady-state mode, dynamic mode, real-time simulation). When paired with AVEVA Unified Engineering and other AVEVA tools (e.g., AVEVA PI System), this reusability becomes practical and measurable. Many standalone simulators are optimized for a narrower slice (e.g., FEED) and lack the same lifecycle handover story.
- Interoperability with 3D models, P&IDs, and electrical/instrumentation data. AVEVA Unified Engineering brings 1D, 2D, and 3D discipline data together. AVEVA Process Simulation’s integration means process results can directly influence datasheets and 3D design, and vice versa, tightening design consistency in ways that matter for constructability.
- Cloud-first collaboration and governance. CONNECT and AVEVA Unified Engineering provide options for hybrid cloud deployment, role-based governance, and project-level services. This modern deployment model simplifies large, distributed projects in ways legacy simulators don’t always support.
What does this look like in action?
Imagine a typical FEED. Process engineers size vessels and compressors in AVEVA Process Simulation and publish operating points and datasheets into AVEVA Unified Engineering. Control engineers use these datasheets to configure I&C. 3D designers verify equipment fit in the model. When operating scenarios change, simulation updates propagate through engineering deliverables. Later, the same model is used for operator training and performance monitoring via AVEVA PI System. The whole project becomes faster, less error-prone, and more sustainable.
Final take
Integration isn’t an engineering novelty. It’s a practical, proven way to deliver modern projects: multidisciplinary, distributed, and lifecycle focused. By embedding AVEVA Process Simulation into AVEVA Unified Engineering and CONNECT, AVEVA has transformed process simulation from a one-off design tool into a reusable, governed asset that enhances design quality, reduces risk, and accelerates delivery. For organizations that care about reducing rework, improving traceability, and extracting value from simulation across operations, this integrated approach is your competitive advantage.
Related blog posts
