Simulating grid-scale battery life
Posted: November 02, 2026
- The profitability of battery energy storage systems (BESS) depends in no small part on how long the batteries last.
- BESS have different ways of making money, with some revenue streams causing batteries to degrade faster than others.
- New research from U.S. researchers uses new simulation techniques to better model the lifespan of BESS under real-world conditions, allowing merchants to make more informed decisions about how to make their BESS installations profitable.
Grids are increasingly using battery energy storage systems (BESS) to both regulate grid frequency and engage in energy arbitrage, storing energy when demand is low and releasing it when it’s high. How well those BESS investments pay off depends on how long they can operate. So, grid operators have to wonder, “will switching my BESS from energy arbitrage to frequency regulation or vice versa decrease its lifespan?” Researchers at Oak Ridge National Laboratory (ORNL) in the U.S. have developed new computer simulation techniques to predict how the configuration of batteries—and how grids use them—will affect their lifespan under real-world conditions.
The two traditional methods of assessing battery life aren’t good at answering those questions. The first, equivalent circuit models (ECMs), rely on simplified models of battery cells operating under ideal conditions. But grid-scale batteries consist of hundreds of thousands of individual cells, grouped into hundreds of modules, which are then wired together into larger units. For a given number of modules, wiring more in serial increases the system’s operating voltage and lowers the current, whereas wiring more in parallel increases current and decreases voltage. ECMs have trouble modeling how individual cell degradation influences the degradation of those different module configurations.
The second method fits mathematical models to experimental measurements of how batteries age. But because they’re calibrated on data from particular tests, they may not apply to batteries used under different operating conditions or built with different chemistries.
Our Industrial Life—delivered
As study-author Srikanth Allu puts it, “the previous battery health systems use a single cell to make their predictions, whereas we are trying to focus holistically not just at the cell level on how the cell degrades but also how the cells are connected and how these interactions between cells aggregate towards a system level performance or degradation.”
The new technique uses high-performance computing (HPC) to simulate how different configurations of cells and modules will perform after 500-1,000 operating cycles. The high-performance computing speeds up the simulations from weeks to just days.
“The simulations provide new insight into why batteries may degrade at different rates and point to opportunities to design battery systems that better balance performance, lifetime, and economic return,” says Allu.
What degrades grid-scale batteries the most?
Batteries that regulate grid frequency undergo small, rapid discharges and recharges to compensate for subtle fluctuations in grid current. By contrast, batteries tasked with energy arbitrage—storing energy when prices are low and putting it back on the grid when prices are high—usually discharge much more energy over longer periods of time. The simulations concur with previous research showing that those deeper, longer discharges tend to degrade batteries more quickly than the short, shallow cycles that regulate grid frequency.
But grid operators are increasingly allowing BESS to fulfill power demand and regulate frequency at the same time. ERCOT and CAISO in the U.S. and NEM in Australia already allow the practice—called stacking—and Ontario’s IESO recently proposed allowing it as well. So, grid operators worry that combining rapid, shallow discharges with prolonged deep discharges will degrade battery life even faster.
Earlier experiments suggested that layering frequency regulation on top of arbitrage adds only modest wear. The ORNL simulations found that mixed schedules of energy arbitrage and frequency regulation reduce capacity more than frequency regulation alone, but not as much as pure energy arbitrage. So operators can tune the mix to balance revenue against battery life and get the most value out of their batteries.
The study finds that the different uses degrade batteries in different ways. The rapid, shallow discharges used for frequency regulation cause electrodes to swell, eventually creating microcracks and diminishing electrical contact. The deep charge cycles used for energy arbitrage can lead to increased solid electrolyte interphase (SEI) growth and lithium plating, processes in which lithium that should be shuttling back and forth carrying energy instead deposits on the surface of the battery’s anode, permanently diminishing the battery’s capacity.
The simulations also show that—in general—both higher-voltage and lower-voltage battery systems degrade at similar rates. But, the cells in high-voltage battery packs age more consistently. By contrast, in low-voltage packs, some cells degrade much more quickly than others. That’s because lower-voltage batteries have more parallel connections and are prone to more current imbalance.
In all batteries, degradation of the whole pack is largely driven by just a few cells reaching their end of life faster than the rest, but low-voltage batteries are more likely to have cells that age much more quickly than others.
The study authors hope that understanding on how battery packs are aging at the level of individual battery cells can help grid operators make better decisions about how to trade off the revenue from energy arbitrage and frequency regulation against the cost of battery degradation. It could also help them optimize maintenance intervals and target warranties for BESS installations.
Future research on battery degradation simulation and BESS performance
Allu and his co-authors are developing their battery simulations as part of the U.S. Department of Energy’s Rapid Operational Validation Initiative (ROVI), which is developing new tools to test and validate new energy storage technology so it can go from the lab to the marketplace as quickly as possible. Their next step is to apply the simulations to a wide variety of conditions, like different configurations and chemistries, states of health, and operating temperatures.
“Simulations at this scale can significantly reduce the need for costly, time-intensive, full-system testing to evaluate battery aging,” Allu says.
