The up and increasingly down history of the U.S. Strategic Petroleum Reserve
Posted: November 02, 2026
- The U.S. Strategic Petroleum Reserve (SPR), founded in the wake of the 1973 oil crisis, is at its lowest level in decades.
- Replenishing and modernizing the SPR would cost billions of dollars, at a time when the strategic significance of oil is waning.
- At present, the SPR is primarily a geopolitical tool, but its utility in that regard is increasingly limited—one future for it could be as a profit-making “sovereign oil fund.”
The Strategic Petroleum Reserve is, um, barrelling towards uncharted territory. Established in response to the 1973 oil crisis, the SPR is now close to its lowest level since weekly records began in August 1982. There is even some debate about whether the reserve is approaching its operational limit—the point at which further withdrawals could threaten its structural integrity.
That’s because the crude in the SPR is not stored, as one might assume, in a collection of above-ground silos, but in 60 gigantic salt domes. These underground caverns—each of which is (very) roughly the size and shape of a large skyscraper—are hundreds of meters underground, and thus subject to complex geological forces that make them surprisingly delicate.
Our Industrial Life—delivered
Factor in the rapid electrification of industry, which is chipping away at oil’s strategic significance, plus growing questions about the SPR’s ability to affect the price of oil, and an important question presents itself: After an extremely eventful 50-year run, is this the beginning of the end of the Strategic Petroleum Reserve?
Crisis and scandal: the early years of the SPR
The SPR was established following the 1973 oil crisis, during which the U.S. economy’s deep reliance on imported crude was devastatingly exposed.
When President Gerald Ford signed the creation of the SPR into law in December 1975, with an initial target of 500 million barrels, there was an urgent desire for a tool that could reduce the political leverage of oil-producing countries and give the U.S. government wiggle room during a future crisis.
By the end of the decade—and with the country in the throes of another oil crisis—the reserve contained just 91 million barrels, or “barely 11 days’ worth of foreign oil at current levels of import,” as the New York Times lamented at the time.
Dysfunction at the SPR soon turned scandalous. A 1982 investigation by the Government Accountability Office (GAO) found, in the words of a UPI wire, “$20,000 in endorsed checks […] in unlocked drawers” and evidence of “drilling bits being thrown away after use, then retooled and sold back to the department.”
According to one of the investigators, 25 criminal fraud investigations had been initiated in the preceding two years, including numerous alleged cases of low-grade “fudge oil” being substituted for the purchased high-quality crude.
Further concerns emerged about the safety, security, maintenance and management of the SPR. Between 1983 and 1985, operations were overhauled under the supervision of the Department of Energy’s Oak Ridge office.
Cavern creep and disrepair: SPR infrastructure today
The fundamental workings of the SPR remain unchanged from the approach outlined in the initial plans. Each cavern is filled with light oil sitting atop heavier brine. When oil needs to be added to a cavern, brine is pumped out to make room for it. During a drawdown, water is pumped in, thereby raising oil out of the cavern. “The caverns are thus always completely full of liquid; the only thing that changes is where the oil-brine boundary is,” explains Brian Potter in Construction Physics.
Source: From a 1978 environmental impact statement by the U.S. Department of Energy.
The caverns are not static, however. Because they are deep underground, they are subject to tremendous pressure. In a phenomenon known as “cavern creep,” this sustained force gradually squeezes their walls inwards. Ordinarily, the effects of cavern creep are staved off by the presence of the liquid inside the caverns. Occasionally, however, caverns have to be completely emptied to allow for maintenance. It is during these periods of “workover” that cavern creep can take effect. Conversely, each time oil is drawn from a cavern, fresh water is pumped in, which further dissolves the walls.
The newer caverns have been excavated with these geological considerations in mind, but some older caverns, which are shaped more like stadia than skyscrapers, are so fragile that they only have a handful of drawdowns left in them.
What’s more, there are concerns that, if levels drop too low, the caverns will be damaged to the point where it will become hard to extract crude with the speed and predictability required for the SPR to be effective.
No one knows for sure where the operational floor of the SPR truly lies. The DOE claims it’s as low as 70 million barrels, but a recent survey of 72 oil and gas executives by the Federal Reserve Bank of Dallas suggests it could be as high as 200 million barrels.
And then there is the surface infrastructure, which has fallen into an alarming state of disrepair.
Back in 2016, Congress approved $1.4 billion for essential maintenance work, which would extend the life of the SPR’s four sites by 25 years. The Life Extension Phase 2 (LE2) project has not been a success. “Due to myriad challenges and repeated scope reductions,” reads a GAO report from earlier this year, “[the Department of Energy’s] decade-long effort to update the aging SPR infrastructure through LE2 is taking much longer than expected and accomplishing significantly less than needed to meet its goal.”
Yet for all the operational troubles and questions over the lifespan of certain caverns, the same GAO report recognizes that the “DOE successfully met directives to carry out increasingly frequent and large-scale drawdowns from the SPR over the last decade.”
The SPR remains operational—at least for the time being.
Outflanked and underpowered: the SPR and the modern energy landscape
A more pressing question is whether the SPR has outlived its utility. After all, the energy landscape has changed almost beyond recognition since the inception of the reserve in the 1970s.
On the one hand, there is the energy transition. In the critical realms of transportation, power generation and heavy industry, oil now has serious competition. Although global demand for oil has not yet peaked, the presence of an alternative energy source reduces oil’s strategic importance.
On the other hand, there is the shale boom. The SPR was created in an era when the U.S. was a massive importer of oil and gas; nowadays, thanks to the fracking boom of the 2010s, it is a net exporter.
In practical terms, the shale boom has also constrained the SPR’s capacity to get additional crude into the market. Pipeline and processing infrastructure across the country is now fully occupied servicing the shale industry. This has “significantly reduced the ability of the SPR to distribute incremental volumes of oil during possible future oil supply interruptions,” notes the Department of Energy’s 2016 long-term review (emphasis added).
Perhaps as a result of all these factors, the underlying assumption behind the SPR is coming under increasing scrutiny, with economists questioning to what extent releases from the reserve actually impact consumer prices. In 2020, for instance, economists at the Dallas Fed published a paper in which they concluded that the effects of releases were at best “modest” and depended on the precise release mechanism.
At the time of the major 2022 release, the U.S. Treasury Department claimed the SPR intervention resulted in gas prices being 13–31 cents/gallon lower than they otherwise would have been. “Modest” indeed—and some experts doubt the accuracy of even these figures.
In a paper for the Oxford Institute for Energy Studies (OIES), Senior Research Fellow Ilia Bouchouev said the Treasury Department’s claims were “based on rather shaky theoretical grounds” and concludes: “In the modern era of digitalization and quantification of everything, any attempt to impact oil and gasoline prices via the SPR will likely result in a waste of resources and taking unnecessary speculative risks on behalf of taxpayers.”
Replenishment, retirement or something else: What next for the SPR?
Filling the SPR back to its maximum capacity would cost about $20 billion, according to the DOE. Congress is very unlikely to approve anything close to that amount. Meanwhile, the Trump administration has floated the idea of using Venezuelan oil to refill the SPR—but Venezuela’s fields need investment and its crude is heavier than the oil the SPR is designed to store.
So should the U.S. instead look to wind the whole thing all up? That might be rash. Writing in 2018, researchers at Columbia University make a point that holds true today: “Given the high degree of uncertainty about the future of both U.S. and world supply and demand and the value of the SPR in a changed oil market, the burden of proof rests with those who wish to sell it off.”
There is a third option. The SPR could be relieved of its geopolitical duties and left to operate as a kind of sovereign oil fund—an asset to be maximized for the benefit of citizens, not a panic button to be pressed in case of emergency.
This would entail the SPR putting its still-huge reserves to work in the market, primarily through swap contracts with energy companies. “SPR loans or exchanges provide returns to U.S. taxpayers effectively with no risk, particularly […] when spot prices exceed futures prices,” observes Bouchouev of the OIES. If those running the SPR learned “the techniques used by private storage managers,” the SPR could easily cover the ~$200 million/year costs of its own operation and contribute positively to the government’s budget.
