Better data, better paper: Turning variability into advantage with AI-ready pulp & paper operations
Posted: July 22, 2026
In pulp & paper operations, even small improvements—fewer breaks, reduced variability, better energy intensity—translate into major financial and sustainability outcomes. AI is gaining traction because it can help teams stabilize performance across complex, interconnected processes. But success depends less on algorithms and more on whether the mill is truly data ready.
Why AI matters now in pulp & paper
Operational physics are unforgiving: fiber and furnish variability, paper machine dynamics (breaks and profiles), energy-intensive dryer sections, recovery area constraints, and critical rotating equipment. Meanwhile, reliability and safety risks rise as assets age, and sustainability is shifting from reporting to day-to-day operational control—especially around energy, water, and effluent outcomes.
AI helps teams respond faster and more consistently by detecting patterns that precede instability, losses, or degradation.
Common challenges mills hit when scaling AI
AI initiatives often stall because:
  • High-frequency signals aren’t captured consistently
  • Data lacks context (grade changes, operating modes, maintenance, breaks)
  • Teams can’t trust the outputs due to lineage/quality gaps
  • Insights aren’t embedded into control room and reliability workflows
Ownership is fragmented across OT/IT/engineering/data
High-value pulp & paper use cases to start with
With a trusted data foundation, AI can drive impact in areas such as:
  • Break reduction and runnability: Detect early indicators, reduce excursions, and improve operator situational awareness
  • Quality consistency: Predict moisture/strength variability, reduce defects and waste, and accelerate root cause analysis
  • Energy optimization: Improve steam and power efficiency, and reduce energy/ton and variability in dryer sections
  • Recovery cycle performance: Optimize recovery boiler and recausticizing performance within constraints
  • Predictive maintenance: Detect early degradation in fans, pumps, refiners, turbines, drives, felts/rolls, and other critical components
  • Water/effluent performance: Support compliance and reduce excursions through earlier detection and better operational control
What AI-ready operations really means in pulp and paper
In pulp & paper, AI is only scalable when data is available, contextualized, governed, and trusted, so that it can be used by both people and machines, and so that recommendations are credible in environments where even seemingly small decisions matter.
The mills that win with AI treat it as an operational capability, built on industrial-grade data, not a one-off analytics project.
Related blog posts
