From pilot to profit in green hydrogen
Posted: December 10, 2025
Opening monologue
“Imagine, if you will, a company on the cusp of greatness. The politicians have cut the opening-day ribbon, the press has filed glowing headlines, and the promise of green hydrogen fills the air. Policymakers cheer, investors smile, and the world waits for transformation. Yet behind the applause lies a different reality — a place where projects stall, costs climb, and the line between ambition and achievement blurs. This is the twilight zone between pilot and profit.”
Green hydrogen facility with wind turbines and storage tanks, symbolizing the transition from pilot projects to scalable, profitable clean energy production. Green hydrogen pilot facilities like HydraGen’s mark the frontier between proof of concept and commercial success.
The protagonist
Our company—HydraGen—is a joint venture between renewable developers and a chemicals offtaker. Their ambition: to prove green hydrogen could be produced at competitive cost and decarbonize energy-intensive processes like ammonia, refining, and steelmaking. Backed by generous subsidies and hopeful investors, they built a 20 MW pilot facility—a fraction of the gigawatt scale experts agree is needed for true competitiveness. Photographs show wind turbines turning on the horizon, storage tanks gleaming, and executives smiling at the ribbon-cutting ceremony.
But within weeks, optimism turns. Renewable intermittency wreaks havoc on electrolyzer utilization. With efficiency rates hovering around 60–65%, the cost per kilo of hydrogen remains stubbornly above $5—far beyond the $1–$2 target needed to displace fossil-based hydrogen. Energy bills surge, OPEX climbs, and the promise of competitive green hydrogen slips into what insiders call “pilot purgatory.”
HydraGen has entered the twilight zone of the energy transition: the uneasy space between proof of concept and commercial viability. What began as a showcase of possibility now tilts toward uncertainty.
The struggle
Inside the plant, engineers search for answers. Why won’t the design scale? Why does each adjustment seem to add cost rather than subtract? They confront a wall of realities: electrolyzer degradation, unstable output tied to renewable supply, ballooning OPEX, and transport and storage constraints. Investors whisper about stranded assets.
HydraGen is not alone. Others faced similar crossroads—and some, like Protium, found a way through.
Protium, the United Kingdom’s largest green hydrogen developer, turned to digital tools to strengthen its operations. The results are striking: a projected 295% ROI, with staff time reduced by 30%, reliability improved by 15%, and maintenance costs cut by 15%.
HydraGen, however, cannot yet replicate these gains. Their project remains a maze of complexity where the exit stays hidden.
The turn
The breakthrough comes not from more steel and concrete, but from industrial intelligence.
Stage
Challenge
Industrial intelligence solution
Stage
Pilot
Challenge
Low electrolyzer utilization; high OPEX
AVEVA™ Process Simulation optimizes electrolyzer design and renewable integration
Stage
Scale-up
Challenge
Complex, siloed engineering
AVEVA™ Unified Engineering enables collaboration and reduces rework
Stage
Operations
Challenge
Downtime, asset degradation
AVEVA™ Predictive Analytics and AVEVA™ PI System™ improve reliability and efficiency
Stage
Profitability
Challenge
Pressure to cut costs and emissions
CONNECT platform integrates data for continuous performance improvement
How industrial intelligence bridges the gap from pilot to profit in green hydrogen production.
HydraGen turns to AVEVA Process Simulation, modeling electrolyzers and Power-to-X pathways virtually. Thousands of scenarios are tested before touching a single valve. They introduce CONNECT industrial intelligence platform, creating a unified environment—a digital twin for hydrogen—where renewable inputs, electrolyzers, and storage interconnect seamlessly. AVEVA Predictive Analytics, paired with the AVEVA PI System, begins flagging failures before they occur. Downtime falls, efficiency rises, and the levelized cost of hydrogen bends toward competitiveness.
The atmosphere shifts. The pilot stabilizes. Maintenance drops. Investors, once skeptical, now see a credible plan: scale from 20 MW to 200 MW and beyond. What once felt like a mirage begins to take solid shape.
Closing monologue
“HydraGen is no longer a company lost in transition. By turning to industrial intelligence, they found the path out of the twilight zone—from ribbon-cutting optimism to commercial-scale reality. And while their tale may be fictional, the proof points are not. Across the world, others are already cutting costs by double digits, achieving triple-digit ROI, and fueling turbines with hydrogen at scale. In the twilight zone of the energy transition, the line between promise and profit is perilously thin. But with the right tools, that line can be crossed. Not someday, but today.”
Many pilots struggle with low electrolyzer utilization, fluctuating renewable supply, and high OPEX that drive the levelized cost of hydrogen above market thresholds. AVEVA Process Simulation helps optimize design, AVEVA Unified Engineering enhances collaboration, and AVEVA Predictive Analytics with the AVEVA PI System provides real-time insights—reducing risks that prevent scale.
AVEVA Process Simulation enables engineers to virtually model electrolyzer systems and Power-to-X processes, testing thousands of scenarios. This reduces CAPEX, improves design efficiency, and ensures scalability from pilot to commercial facilities. Learn more in our blog Unlocking green hydrogen potential with AVEVA Process Simulation.
The AVEVA PI System contextualizes real-time plant data. Coupled with AVEVA Predictive Analytics, it reveals hidden patterns, predicts failures, reduces downtime, and strengthens asset reliability across hydrogen production facilities.
Green hydrogen projects span multiple engineering disciplines. AVEVA Unified Engineering creates a single shared data environment, eliminating silos, cutting rework, and accelerating project delivery.
By optimizing hydrogen production efficiency, AVEVA solutions reduce wasted energy and emissions. Scaling these efficiencies accelerates the role of green hydrogen as a practical decarbonization pathway for industries like chemicals, refining, and steelmaking. See an infographic of AVEVA’s role in hydrogen.
Take the next step
To explore more real-world wins in the energy transition, watch our on-demand webinar: Industrial intelligence and the impact on decarbonization.
Related blog posts
