Why shipbuilding needs a new approach to engineering
Posted: November 02, 2026
The pressure on shipbuilding is intensifying.
Vessels are becoming more complex. Skilled talent is increasingly difficult to find and retain. Shipyards face full orderbooks and demand that continues to outpace available capacity. Shortening delivery times is therefore not only about meeting schedules—it increases a shipyard's ability to build more vessels and respond to market demand.
At the same time, shipbuilders are managing increasingly complex volumes of engineering information across design and delivery. Without effective management and continuity of that information, the risk of errors, delays and miscommunication increases significantly—directly impacting productivity, quality and delivery performance.
More complexity. Fewer resources. Greater pressure to deliver.
Shipbuilding has always been complex. Multiple engineering disciplines, suppliers, systems, and stakeholders must work together across the design and production process in which thousands of interconnected decisions are being made and changed.
And crucially, the process is not always sequential. Production can begin while parts of the design are still evolving, meaning engineering changes can have an immediate impact on requirements, deliverables, materials and work already progressing downstream.
This makes consistency and control increasingly important. With fewer experienced engineers and resources available, teams cannot afford to spend valuable time searching for information, reconciling different versions of data or manually determining the impact of changes across disconnected systems.
The challenge for shipbuilders is therefore not simply how to deliver increasingly complex vessels. It is how to do so efficiently, with finite engineering capacity, while maintaining control as information and decisions move continuously between design and production.
Productivity cannot simply mean asking engineers to do more
When resources are constrained, increasing productivity becomes critical. But sustainable productivity cannot come from continually asking engineering teams to work faster.
It requires removing the friction and tedium surrounding engineering work.
In traditional engineering environments, information can sit across different applications, disciplines and databases. Engineers spend valuable time finding information, validating whether it is current, transferring data between systems and managing the downstream impact of design changes.
A change made in one discipline can create consequences elsewhere. When information and workflows are disconnected, identifying and communicating those consequences becomes another task for already stretched engineering teams.
Creating a trusted single source of engineering data (with AI-ready API’s) facilitates the successful application of AI by reducing data sources, error checking and false results.
This becomes particularly important at the intersection between design and production.
Shipbuilding doesn't wait for design to finish
Design and production are not always sequential processes.
To meet demanding delivery schedules, production can begin while elements of the vessel design are still evolving. Engineering decisions continue to be made while material is being procured, deliverables are being issued and production activities are already underway.
The difficulty is that production teams may already be working from engineering information while the underlying design is still changing.
A requirement can change. A deliverable can be revised. A design change can affect materials that have already been planned or ordered. Bills of material (BOMs) can evolve while production teams are already relying on them.
When these critical areas are managed through separate systems, documents and manual processes, every change introduces the potential for additional coordination, rework and delay.
And as vessel complexity increases, so does the challenge of understanding not simply what changed, but what that change affects downstream.
This is why greater productivity requires more than improving individual engineering tasks. It requires continuity between the information being created during design and the information being used to build the vessel—with stronger interfaces to production systems helping ensure accurate, up-to-date engineering information can flow more effectively into planning and production.
From fragmented processes to connected engineering
The opportunity is to create a more connected approach to ship design and build: one where engineering disciplines work within a common environment, information can be trusted and changes can be understood across the project.
One connected engineering environment.
One trusted source of engineering and design data.
One digital thread from design through production.
This is where AVEVA™ Unified Engineering and asset lifecycle management (ALM) come together.
AVEVA Unified Engineering provides a centralized environment for multidisciplinary engineering and design, connecting the information and models being developed across the vessel.
ALM extends that continuity into the critical processes surrounding the intersection of design and production through operations—centralizing requirements, deliverables, changes and BOMs as live, controlled sources of truth.
Together, they provide shipbuilders with a single, centralized engineering and design platform through which engineering information can remain connected as the vessel progresses from design into production and beyond.
This matters because the objective isn't simply to store more information in one place.
It's to ensure that the people making decisions are working from consistent, current information, particularly when design and production are happening concurrently.
When a requirement changes, its impact can be managed. When engineering information evolves, the associated deliverables and changes can remain controlled. When production needs a BOM, teams can work from information connected to the current engineering definition.
Instead of relying on fragmented handovers between design and production, information can remain part of a continuous digital thread.
Turning digital continuity into productivity
For shipbuilders, the result is ultimately higher productivity.
Engineers spend less time searching for information, reconciling different versions of data and manually coordinating changes across disciplines and systems.
Production teams gain greater consistency in the engineering information they depend on.
And changes can be managed with greater control across the point where design decisions begin to have real production consequences.
For an industry being asked to deliver increasingly sophisticated vessels with constrained resources, these efficiencies can compound across an entire project.
For shipbuilders, better continuity of engineering information has a direct impact on productivity, particularly when design and production are progressing at the same time.
Building the next generation of Marine Design to Build
This is the challenge we have been working to address at AVEVA.
Our next-generation Marine Design to Build solution brings AVEVA Unified Engineering and ALM together to create greater continuity across the shipbuilding process— connecting engineering disciplines, requirements, deliverables, changes and BOMs from design through production.
The ambition is to help shipbuilders create a more consistent and efficient way of working: reducing engineering friction, reducing errors and translations, improving productivity and maintaining control as increasingly complex projects move from design into build.
This November, we will bring the global marine community together in Malmö, Sweden, to introduce this next chapter.
At the Next Generation Marine Design to Build Launch, taking place 18–19 November 2026, ship designers, shipbuilders, owners, operators and industry leaders will explore the pressures reshaping marine engineering and how a more connected approach can help the industry respond.
We will also unveil AVEVA's next-generation Marine Design to Build solution, with a live demonstration of how AVEVA Unified Engineering and ALM bring connected engineering, trusted information and digital continuity together across design and production.
Because the future of shipbuilding will not simply depend on doing more.
It will depend on removing the barriers that prevent engineering teams and modern automation from doing more with the knowledge, data and resources they already have.
Join us in Malmö to see the next generation of Marine Design to Build in action.
Related blog posts
